跳转到主内容
加入维修社区 - 创建账户
三星 Gravity SGH-T459。于 2008 年 11 月 7 日发布,型号为 T459。
Broken SIM adapter stuck
Samsung Gravity 3 SGH-T459
SIM adapter (without SIM) broken. Lower half of adapter stuck inside SIM compartment.
Any suggestions on how to retrieve the lower half of the broken adapter.
If this doesn't cut it, post a picture so we have a better idea of the extent of your problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The picture and video on the site is not me.
完成的
添加一条评论
2个答案
最有帮助的答案
Use this guide to get to it: https://www.youtube.com/watch?v=Zvjqs5jO...
Now I would just use the tip of my pocket knife to slide it out.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for your interest in this situation. The adapter is hollow in the middle with two small/thin sides. Because of these thin sides the adapter broke into two pieces. The remaining piece is still inside the SIM slot and cannot be seen. It appears that removal will require complete dismantling the phone.
完成的
That is not the way it looked like to me in the guide. Looked to me like you just took the back off, the battery out and had access to it.
完成的
添加一条评论
Had to completely dismantle the phone including the module that holds the camera.
I was able to access the back part of the broken adapter. Note: The adapter has a hole in the middle of it. It appeared to have been caught on the SIM contacts of something else in there.
The problem I have now is how to assemble all this. This part of disassembly is not covered in the iFixit article.
Would appreciate any assistance or references to this. A detailed part list would be helpful.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dgalbrec 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 345
