跳转到主内容
The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
Why does my touch screen don't work?
So I was checking my bag, when I pulled out my clothes from my bag, my phone fell, but I dropped it when my bag was low near the ground, I used the phone in a bus, it worked, but when I was at home, and I couldn't press anything, when I click it, it doesn't work, the back and the other button works though. If I try to restart or power off, it doesn't work because I need to touch either the restart or power off, holding the power button for 10 seconds it didn't get powered off, can someone help me?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
To power it off, hold the power button and volume down until the phone restarts. Power it back on and let me know if touch starts working again. Hope that helps!
这个答案有帮助吗?
得分 4
9条评论:
It fixed :3, I stopped charging for a few days, and it shutted down, I opened it then it worked again!
完成的
@vygantasfix Well that is not good! I have voted to get your comment switched to a question so you can get your device fixed! (hopefully) I can't provide help for you very well, but if that vote passes some other community members might be able to help you. Good luck!
完成的
Thank you Reed. To power it off, hold the power button and volume down until the phone restarts. It worked.
完成的
@negreadd No problem! I'm glad it helped, that's what I'm here for!
完成的
I got exactly the same problem. I managed to restart it, but the touch is still not working. Does that mean I have to replace the touchscreen? Need help
完成的
显示更多的4条评论
添加一条评论
holding the power button down and pressing volume down just takes a screenshot, you cant take off the phone cover or restart the phone without touching it, please i need help, i cant get another phone, someone tell me a solution
这个答案有帮助吗?
得分 0
添加一条评论
My phone toch stops working i tried to reset through power and volume button it does not work and os downloading starts and stuck
这个答案有帮助吗?
得分 0
1条评论:
I had the same issue with my tab. the thing was I did not charge it for a long period so battery was empty and of course the tab turned off. I charged it and the touch screen was not responding...
my solution: I removed carrefully the back cover, and I disconnected the battery and waited 10 min. then I reconnected the battery to the motherboard and turned on the tab to check that it was working fine again, and of course putted back the back cover.
that was my solution, you may give it a try if your touch screen stopped to respond... but if your phone feld, maybe something broked...
good luck.
完成的
添加一条评论
添加你的答案
Sentai Genji 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 22
总计 15,077
