跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
Cost of fixing the touchbar
There is a crack on the touchbar of my macbook pro 15 inch. The touch is partially functional until the crack. Would like to know the price for repair and IF apple care will cover it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
7个答案
最有帮助的答案
That is not going to be cheap, you basically have to replace the whole main case, with keyboard, battery and perhaps the trackpad.
这个答案有帮助吗?
得分 2
添加一条评论
My keyboard was jam by something, the Apple Store change the whole top case(include Keyboard, Touch Bar, Touch Pad, Top Metal case and battery). It cost me $575.13 in Seoul, Korea.
这个答案有帮助吗?
得分 2
1条评论:
Wow! Really makes you wish that was a more repairable part.
完成的
添加一条评论
I’m going to fix touchbar of my macbook pro. Currently, my cost is $60 for touchbar and $60 for toolkit from Ifixit. shipping and tax around $20. Total around $140. Let’s see i can fix it. I will try to record my repairing process.
BTW, where can i buy screws for Macbook pro 15”inch (2017)?
这个答案有帮助吗?
得分 2
2条评论:
Finally, i replaced my touchbar. screen comes out but touching sensor is not working. I think it is factory defect. I need to contact to IFIXIT. Before my old one was working fine touch sensor but display was not showing.
[image|1844024]
完成的
Yes. I changed and it works perfect.
完成的
添加一条评论
My laptop, which is same as yours, was soaked and the touch bar was damaged too. I went to the apple store and was told that if I want to fix the touch bar, I have to change the whole keyboard.....
这个答案有帮助吗?
得分 1
添加一条评论
My touchbar's cover SOMEHOW popped up and it stopped showing the icons. Took it to the apple store and got told that it costs $750 ($100 labor included) to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
You cannot fix it as the whole logic board will be replaced and it can cost you around $1200-$1500
这个答案有帮助吗?
得分 0
添加一条评论
Possible to fix but not an easy task to do.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nihal Wats 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 32
总计 22,857
