跳转到主内容
Sony CFD-S05 CD Radio Cassette Player was released in 2010, and has the CD-R/RW playback function.
25 个问题 查看全部
Why does the power cut off as soon as I turn on the unit
Power issue with Sony Radio CD player and cassette player CFD-S05
unit is plugged in and I have a second unit that works with the power cord.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Great, i changed the capacitor and ifixit !
完成的
添加一条评论
2个答案
最有帮助的答案
Please check whether your symptom matches The Sony CFD-S05 unit will not power up . I added a detailed answer how I fixed the device there.
这个答案有帮助吗?
得分 2
2条评论:
I have The Sony CFD-SO5 and so how did you go from switched to unswitched ? Did you have to tear the unit apart ? How do you bypass the On/Off button ?
完成的
I did take the unit apart. @oldturkey03 posted a link to the Service Manual. It explains how to take the unit apart. In my unit, the problem was *not* with the power switch, so bypassing either that button or the electronic switch controlled by it would have made everything worse. The actual problem is a short circuit on the main board. You have to fix that. The unit performs a kind of "self-test" every time you try to turn it on, and automatically turns off again if there is a short circuit.
完成的
添加一条评论
Edward Walker you need to take a look at the power supply. Most likely a capacitor or transformer issue. Disassemble your unit CFD-S05 Disassembly and post some images of the power board so we can see what you see. Here is the guide for that 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Edward Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 51
总计 4,022
