跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Black screen of death
So I got the "black screen of death" on my iPhone 7 128gb silver on iOS 10.3 while casually using my phone the other day. The screen faded to black slowly and wouldn't show again, I could feel the home button vibrate so I knew it was still on but the silent switch doesn't make the phone vibrate. so I tried soft reset- didn't work, tried letting it die then charging- didn't work, tried update- didn't work, finally tried restore in both Dfu and recovery mode didn't work, so after that I assumed maybe it was the LCD so I tried a new one that didn't work either.
Now I'm stuck with a paperweight iPhone 7 that is less than a month old, I would contact apple but I was told warranty won't cover it anymore since i opened it to try a new LCD. Is there anything you guys would recommend? Any and all help is appreciated, very little info about my problem online. Thank you for your time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
2条评论
I though the article is useful. At least it helped me exit black screen......
How to Fix iPhone Black Screen of Death
完成的
can i buy it from you
完成的
添加一条评论
10个答案
已选择的解决方案
Put the original LCD back on, and get the phone replaced under warranty. Do not tell them anything about opening the phone, just say one day it suddenly just died like that.
这个答案有帮助吗?
得分 3
1条评论:
You plug into your computer then on your phone you hold power button and volume up for 10 seconds then release volume up keeping your finger on the power button for 3 seconds. It will restart and nothing lost.
完成的
添加一条评论
Hey , i have the exact same problem so I was wondering if you fixed yours at the end and how? What was the cause?
这个答案有帮助吗?
得分 2
添加一条评论
Just power it off by holding power button and volume down. If that doesn’t work try doing it while connected to iTunes. If iTunes logo pops up on phone, disconnect cable from iTunes and power off again. It worked for me. Good luck.
这个答案有帮助吗?
得分 1
2条评论:
Did this whilst connected to iTunes and nothing.
Disconnected and tried the 'power+Vol down' buttons which worked a treat!!
CEO's phone so saved having to send it off for repair!! Thanks a lot!
完成的
Power Button whilst holding volume down worked a charm!!!!!
完成的
添加一条评论
hello
You Need Check Battery With Full charge..... and connect with iTune .. i hope your Phone connected.... if connected you have 2 Problem
1) Chargeing
2) Lcd Light
Thanks.....
I got Same Problem. And Solved..
这个答案有帮助吗?
得分 0
添加一条评论
This happened on a 7 that I fixed about two weeks ago, you need to order either this or something just like it.
https://www.amazon.com/Replacement-TranS...
这个答案有帮助吗?
得分 0
1条评论:
Dead link. Please explain what component you were referring to?
完成的
添加一条评论
Just few hour ago,I still using my ip7 to watch FB live, after awhile I put it back into my pocket like usually did,when I come back home,I wondering why my phone is suddenly black off ,tried charge ,I can feel the electricity going through the phone , but it just black screen like that, vibrate no function, volume down+power doesn't work .... Just a sudden case , and that's the first time I experienced such weird thing,few thousand of photos haven't backup n some important data.... Frustration now.
这个答案有帮助吗?
得分 0
添加一条评论
IPhone 7 plus blacked out and keep going to other stuff without me clicking on it and seems like electricity going through it and it keeps blacking out and IDK why please help
这个答案有帮助吗?
得分 0
添加一条评论
My iPhone 7 plus wont turn on and I have a feeling that it just blacked out. Is there a way I can fix it?
这个答案有帮助吗?
得分 0
添加一条评论
My iPhone won't turn on
这个答案有帮助吗?
得分 0
添加一条评论
Here on 2025, my mom's iphone 7 plus just got the black screen of death ... We did all the things, with holding down button and power button at same time, - doing volume up, volume down and power button, nothing - tried draining the battery, this thing seems to have battery forever all of a sudden (when it would not hold too much battery usually 🫠) and now buying a new one! so sad there's no remedy!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Poop mcgee 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 95
总计 52,751
