跳转到主内容
加入维修社区 - 创建账户
1996 年款车型是在 1995 年北美国际车展上推出的,采用的是 Chrysler S 平台。
car will not move in reverse.
So i have a 97 dodge caravan 2wd 3.3ltr i was backing out of my driveway and it hesitated befor moving but moved about an hour later i got in and put it in reverse and it would not move. Pressed on the gas a little and it still wouldn't move all other gears work and fluids were checked and are good. I can feel it shift into reverse but no movement and when the gas is pressed it rev's and sounds like it puttered like it was about to backfire. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Is the an automatic transmission or a stick shift?
完成的
Automatic transmission
完成的
添加一条评论
1个答案
I would double check those fluids remembering they should be checked warm with the engine running after shifting into all gear options. If this does not work you may have an electrical problem preventing all the necessary solenoids from activating. Your best shot may be to drive it to a repair shop and have them diagnose it. If it is only the solenoid the fix shouldn't cost that much.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sky Simpkins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,912
