跳转到主内容
Nikon Coolpix L18, 8.0 Megapixels, 3x optical zoom, 3.0 inch LCD
4 个问题 查看全部
lens will not extract or retract
Lens on Nikon Coolpix L18 will not extract or retract. I hear the motor running but no movement of lens. Lens cover does work when gears are manipulated by hand. I have the camera disassembled and need some guidance to open correct part of the lens housing to fix mechanics of its movements.
I thank you in advance for your advice.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
sarkis did you manage to fix this problem? if oldturkey's solution has helped would you please come back and accept his answer? thankyou
完成的
添加一条评论
2个答案
已选择的解决方案
Sarkis Paronyan, I do have the complete repair manual and parts list for your camera. Do feel free to download it, it comes in 4 parts that you have to have and the parts list. That manual will tell and show you all you ever wanted to know about your camera. :)
Manual and here is the partslist
Good luck to you and your camera and let us know how it went.
这个答案有帮助吗?
得分 3
10条评论:
oldturkey would you have the guide for the Nikon Coolpix L1 ?
完成的
thanks and sorry for hijacking your answer :-)
完成的
Hello oldturkey03,
Thanks for answering my question however I am late in retrieving these files and they are already removed and I am unable to download them.
If you do not mind replace them and I will download them.
Once again thank you very much for your response and provided information.
Sincerely,
Sarkis Paronyan
完成的
The manual is now available at Manual and here is the partslist Good Luck.
完成的
Hi oldturkey! Can you please upload the manuals again?
Thanks!
完成的
显示更多的5条评论
添加一条评论
Hey oldturkey03 Are you still around? I have come to need the Nikon CoolPix L18 Manual & PartsList, would you please send it my way at christiangrivas@gmail.com
Thank You Very Much
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarkis Paronyan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 4,723
