跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z5 安卓智能手机于 2015 年 10 月发布。Sony Xperia Z5 配备 5.2 英寸 1080 x 1920 像素显示屏,搭载高通骁龙 810 处理器,辅以 3GB 运行内存和 2300 万像素后置摄像头。
While calling phone screen turns off?
While using any calling feature (phone, facebook, etc) my phone screen goes black and won't turn back on, if the other person doesn't hang up first than I have to manually restart my device to end a call. How do I fix this? Seems to only have started after I installed Nougat 7.1.1.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
can i turn off that sensor that make the screen black when covered ?
完成的
添加一条评论
6个答案
最有帮助的答案
Do you have a screen protector or a case that may be covering up the proximity sensor? If not, the proximity sensor itself may need cleaning or replacement.
这个答案有帮助吗?
得分 3
1条评论:
I had this problem and it was annoying, especially when I had to press the dial pad to go to different services from the number I was calling. So I googled it many times and had all these long winded methods. Then I got a post from a bloke that sounded like he was Russian. When making a phone call and your phone goes blank, just press with you finger in the right hand top corner and the screen comes on again. Thankyou Komrade.
完成的
添加一条评论
Make phone call. When screen goes blank, press right hand top corner of screen.
Screens comes on again.
这个答案有帮助吗?
得分 2
3条评论:
Thanks for this very helpful information
完成的
Omg it works thank you!!!
完成的
2023 still using this trick. Tq very much
完成的
添加一条评论
I have that problem also
这个答案有帮助吗?
得分 0
添加一条评论
Well Ensure that the proximity sensor is not being blocked by foreign objects, a screen protector, or a protective case.
Following might be helpful for you: https://wethegeek.com/how-to-fix-android...
这个答案有帮助吗?
得分 0
添加一条评论
Hi, there is 2 type of problem, first clean your sensor, usually top left of mobile phones, Second may your proximity sensor need to be replace.
这个答案有帮助吗?
得分 0
添加一条评论
i just pressed the top righthand corner and the screen came on !!!** weird or what
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Char Duffett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 12,124
