跳转到主内容
加入维修社区 - 创建账户
1.5 GHz Core Solo、1.66 或 1.83 GHz Core Duo,或 1.83 或 2 GHz Core 2 Duo 处理器。 本页面涵盖了从 2006 年初到 2007 年中的首批基于 Intel 处理器的 Mac mini 机型。
Why does the Fan run continuously?
Primary Symptom:
•The Fan runs loudly at full speed, and stays on all the time, as soon as the computer is booted.
Other Symptom(s) or Details:
•All operations of the machine seem to be slower than they used to be, whether using just the OS, or running an application (I do not know if this is a related problem).
•80GB HD with 47GB free space. 1GB RAM installed. Computer is used *only* for email, internet browsing, and to run Finale (music notation software - no audio processing)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Have you check if your fan cable is insert correctly in the cable channel? Open your mac mini and make sure to connect the fan cable!!!
由完成的
Has the machine been upgraded or taken apart recently? There is a sensor at the front of the machine for the hard drive, if it is not reconnected back the fans will run at full speed as soon as the machine is powered on.
由完成的
添加一条评论
3个答案
最有帮助的答案
Possible you forgot one cable in the back of the Mac Mini.
这个答案有帮助吗?
得分 3
2条评论:
Exactly what it was for me. Thanks for posting the picture as well cause once I saw it, I connected the cable.
由完成的
Exactly me too! Thank you!
由完成的
添加一条评论
Download, install and run TG Pro to be able to locate the problem:
https://www.tunabellysoftware.com/tgpro/
这个答案有帮助吗?
得分 1
添加一条评论
Heat sinker must be cover with thick dust and the fan is working overtime to keep it cool. Open unit and with a compress air can blow it clean. Some of the current drawn by the fan pull resources from other components (CPU, video, USB, etc...) slowing everything else.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ed Maceachen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 4,600
