跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Blue Bubble on Screen
I replaced my battery and now I have 2 blue bubbles that I can only see on a white screen about an inch above my home button. I'm pretty sure its cause by pressure because when pop the screen up it goes away. Please help me! Its really annoying. What is causing this and how can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Is the iPhone metal housing frame bent let's say around middle of phone?
This can cause uneven surface for all the components on the phone and can cause this issue.
Another reason is that the replacement battery is just too fat if you get what I mean.
What adhesive did you use under the battery?
Some adhesives may be too thick to use.
这个答案有帮助吗?
得分 2
1条评论:
Pretty sure it's the battery. Metal isn't bent so I'm just gonna ask for a new battery and see if that works. Thanks!
完成的
添加一条评论
Most likely an off brand battery might of expanded I would replace asap
这个答案有帮助吗?
得分 0
添加一条评论
Try to take off the LCD shield plate and see if it comes back then. I have had few times little piece of glass or something hard between the shield plate and screen which causes pressure to the LCD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Konnor Bass 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 413
