跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
176 个问题 查看全部
Muffled Microphone - iMac 21.5" (mid 2017) - Following Adhesive Strips
This is actually an answer rather than a question; a solution to a problem that is not yet in any guides. Since I couldn't find a resolution online, I figured I'd share my own.
The mid 2017 21.5" model of the iMac is new and this issue isn't major, so it's not surprising that the few people who have sewn up their computers after an upgrade or fix either haven't encountered it yet, or found the true cause.
The problem is that after reassembly, the microphone input is faint and muffled. It functions, but barely, and is essentially unusable. The culprit turns out to be the adhesive strips used for reassembly. The frame of this iMac model seems identical to its 2012-2015 predecessors, so ostensibly the same strips made for these earlier models would work here too. However, the microphone has been moved from the top of the computer (near the webcam) to behind the frame at the bottom of the screen.
Note the location of the "4R" strip in the following picture:
https://d3nevzfk7ii3be.cloudfront.net/ig...
Now look at the location of where the microphone has been moved to:
One can clearly see that the "4R" strip completely covers the microphone and the holes in front of it, deadening any sound picked up.
Knowing this, the solution is simple. Make sure the microphone works properly before using any adhesive. Then, apply the adhesive strips, but when laying down the "4R" strip, cut away the portion covering the microphone (and a little bit more from each side to be safe).
Hopefully, this post will save others from hours of exasperation! :)
Cheers!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 64
44条评论
2 weeks at AppleCare, still not resolved. Have to take back. Losing money on freelance every day!
完成的
I had the exact same issue with the 2017 27" iMac. This post gave me a clue of what was going on. Thank you!
完成的
Thank you very much! your post saved my time too :-)
完成的
Not received this type of iMac yet, but a big thank you for the heads up as this is easily overseen!
完成的
Thank you very much!!! This post saved me a lot of time.
完成的
显示更多的39条评论
添加一条评论
4个答案
已选择的解决方案
@iofile Better go here and create a technique tutorial about this it will be more efficient than a answer in a question. If you dont want to do it just tell me and I will enjoy doing it in your place.
这个答案有帮助吗?
得分 10
12条评论:
Yes, I would love to write a guide on this. The only complication is that I'm out of town atm, so it would probably be a couple weeks before I could write and post it. Is this an acceptable time frame?
If you think people could benefit from having this information sooner, then perhaps you should tackle it. Thank you for the interest!
完成的
Can you tell why strip is covering the mic? Can it be while producing computer? Or it is 100% physical modification by users? I ask that because suspect that the person who sold me a "new" iMac might fool me. BTW I have iMac 2017 5k Z0TR/5 model
完成的
@bora89 this happens when you open your Imac and you gonna use another adhesive tape to reseal the machine. What seem to be the problem with yours?
完成的
Yes, it is muffled. But I did not open my iMac, I bought "a brand new iMac" that I was told, all the one way unsealing tapes were on box. I just do not understand.
完成的
If is brand new you can check you warantie coverage for it , if is still in warranty just get it changed by Apple https://checkcoverage.apple.com/
完成的
显示更多的7条评论
添加一条评论
for future fixers, here’s some verification of the above info. The first photo is how I found the adhesive as soon as I peeled it off, clearly a clean cutout of the adhesive from the factory for the microphone. And then the second photo after I uncovered the other two holes.
这个答案有帮助吗?
得分 5
添加一条评论
Hi! For anyone who ends up here in / after 2019, our iMac Intel 21.5" Retina 4K Display (2017)胶带更换 guide accounts for this issue, and all corresponding procedures link to that guide. Happy fixing!
这个答案有帮助吗?
得分 3
6条评论:
I just use a single hole paper punch to cut out the needed area in the tapes. It doesn't take that much of a cut.
完成的
In the iMac 27" guide I did not find any hint for this.
I upgraded Blade SSD and CPU on my iMac 2017 with the corresponding guides and now I have to remove the screen again and buy new tapes.
完成的
So I did not realize Apple moved the mic from the top of the iMac frame to the bottom of the aluminum frame. The lcd actually covers the mic location and the double sided adhesive tape holds the lcd in place. The tape will cover the mic if you don’t cut the tape to allow for the mic. So I removed the lcd and discovered that my tape job covered the mic. I removed the tape around the mic going a 1/2 inch out on both sides.
I closed it completely up but didn't apply new tape yet, tested the mic and it still sounds odd, better than the first time I closed it (there were echos and screeching) but still not right.
Has anyone replaced the mic yet?
完成的
macisgr8 Exactly my problem. The mic picks up after tape removal, but not as good as it was And sounds like I’m in the bathroom.! What could have happened?
完成的
@macisgr8 Hi I have exact same problem, removing adhesive not helping the mic. Did you find any solutions yet?
完成的
显示更多的1条评论
添加一条评论
Eve Ann Wallis - This series has a unique issue! Apple moved the microphone hole! And in doing so have messed up a few people. You need to modify the bottom tape with a small cut out so the hole is not covered. Here’s the location of the microphone hole:
At this point you should get another adhesive tape kit and after fully cleaning the old tapes off, modify the new set as needed but cutting a small area at the bottom edge of the strip where the mic is and give that a go!
But, before you put the display back on check your mic cable is connected properly as outlined in step 57 in this guide and the ribbon cable is not damaged iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement
这个答案有帮助吗?
得分 1
2条评论:
Thanks for this, it's most helpful. I've already ordered new adhesive strips. Funny thing is that today the external drive is recognised in disk utility but not in Finder, whereas yesterday it wasn't recognised anywhere.
完成的
Confirmed. Re-did the adhesive cutting the whole for the mic. I got the opposite piece (4L) too because I wasn’t sure if that was also a mic hole. Sounds is great now.
完成的
添加一条评论
添加你的答案
Warren Wilson 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 50
过去 30 天: 249
总计 39,146
