跳转到主内容
问题已关闭
Power supply connector
I recently replaced a hard drive on my ibook g4 per your instructions. Unfortunately I inadvertently pulled the power supply connector off the logic board. Can this be fixed and is it worth the price?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Please read my answer in this thread:
http://www.ifixit.com/Discuss/thread/596...
这个答案有帮助吗?
得分 1
1条评论:
I'll second his procedure as the safest way if you decide to solder. Ralph
完成的
添加一条评论
最有帮助的答案
An alternative solution to the rather delicate process of soldering would be to try a non conductive glue. My reasoning being that if you make the contact with the wire to the contact, you stand less chance of excess solder running over printed circuit and causing shorts, bridging or other problems.
This is only my theory and an experimental idea, but it's worth a try before replacing the enitre logic board.
Good Luck
Frank
这个答案有帮助吗?
得分 1
2条评论:
I've done this with superglue, but the risk is that you have to be 100% certain it is in the proper position before gluing, otherwise it's very easy to glue it down and discover the contacts are not touching and it's stuck to the board in the wrong position. I recommend fast-drying superglue, and pressing down on the plug for 5 minutes while it is drying. If this fails, you can always go the soldering route.
完成的
I was rethought the solution. Perhaps a removable glue such as hot glue or rubber cement will do the same job but leave you room to abort the mission with out the relative permanence of superglue.
完成的
添加一条评论
I'm guessing you are referring to the power on switch connector. Its possible if you or someone you know is very very good with a soldering iron you might be able to restore the connector to the logic board. What you are probably looking at is a logic board replacement. Ralph
这个答案有帮助吗?
得分 0
添加一条评论
Thanks I will try the superglue route first.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,494
