跳转到主内容
发布于2013年11月22日的微软第三代Xbox游戏主机。
20 个问题 查看全部
My xbox is trippin
Every time I turn my Xbox on the controller never connects and the screen is always blank all the controller does is blink and then it will turn off by itself. Please help I miss playing cod.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
Firsts things first! Try unplug power supply from outlet. Let power supply discharged and the orange led is off. Connect Xbox one to the power supply and then plug your controller with cable and if it has battery remove them. Try turn it on and check power supply led and give feedback if problem persists. Good luck and relax. Probably it is something you can fix!
这个答案有帮助吗?
得分 2
1条评论:
Very important I forget. HDMI cable!!!! Find another one to check!!
完成的
添加一条评论
Also, make sure you check the HDMI port, there are 2 on the Xbox One. One for HDMI in (cable/satellite receiver pass though) and HDMI out, that one goes to the TV.
这个答案有帮助吗?
得分 1
添加一条评论
Try to re-sync your gamepad after you powered on the console.
这个答案有帮助吗?
得分 1
添加一条评论
Sell it and get an Xbox one s they are far better than the original and you can get them pretty cheap with games , not only will you get an amazing gaming machine that has been slightly overclocked over the original you also get a uhd 4K Blu-ray player ... the cheapest stand alone 4K Blu-ray player will cost you two hundred dollars by itself .... just sayin
这个答案有帮助吗?
得分 0
添加一条评论
sometimes when the xbox is completely off, the controllers won't wake it. turn the xbox on by waving your hand over the sensor on front, and then connect your controller.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Durk Banks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 607
