跳转到主内容
Model MD2614u / AMD Turion X2-64 2.1GHz dual-core processor
13 个问题 查看全部
black screen when powering up, Can see shadows behind it?
My child was watching Netflix on the laptop. After watching the movie, she closed the top off the laptop down. I went and opened it back up and there was a black screen and I could see shadows of the icons and a pop up saying windows was not properly shut down.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Can you shut it down and restart. Sounds like your backlight is out. Looks to me like you need either a backlight or a new inverter. Your LCD is okay as long as you can see your icons etc. Of course first try to shut it off and restart after and see if that will resolve the issue. http://www.batterycentury.com/gateway-md... has the inverter. Hope this helps to clarify this a bit. Good luck and let us know what happened.
这个答案有帮助吗?
得分 2
1条评论:
+ I agree and would check the inverter first
完成的
添加一条评论
My display is doing the same thing. The backlight comes on when booting up and goes off at windows login. Any suggestions?
Update
I fixed it. Anyone having this problem just restart in safe mode by pressing F8 while booting up, then using the arrows go down to where it says restore windows to a point where it loaded properly (not sure the exact language)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacquie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 2,620
