跳转到主内容
加入维修社区 - 创建账户
“这款全球最小的 15.6 英寸笔记本电脑,在戴尔性能最强的 XPS 笔记本电脑中,汇集了强劲的性能和令人惊艳的 InfinityEdge 显示屏。”
How do I replace the audio jack?
My audio jack is faulty. Can't afford a new motherboard. Where can I find a replacement audio port?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Actually, the XPS15 9550 is barely or under a year old. Dell should replace it for free. IF not, check the credit card you purchased with, and they may cover the warranty for an extra year.
由完成的 分享
It has a broken headphone jack stuck in it. Dell said it won't be covered under the warranty period as its negligence/damage.
由完成的 分享
添加一条评论
1个答案
The audio connector is part of the mother board. Unfortunately, Dell has decided that this problem is not warrantable. You may be in luck if the problem is a broken off part of a head phone jack and not a broken connection on the mother board. You may be able to remove the boken head phone part by using tweezers or use a paper clip bent into a small hook to pull the broken part out. You may be able to find a computer repair shop that can do this for you. Worst case is you may need to use a USB type audio head phone. Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ketan Krishna 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 1,670
