跳转到主内容
Guides and support for various television (TV) brands and styles.
9059 个问题 查看全部
Crack visible on LCD when screen is on.
My 70" SAMSUNG UA70KU7000KXXA UHD FLAT SMART TV Screen has a crack straight down the left hand side of the screen only visible when the unit is powered on. There is colour on the outskirts of the screen other than that everything is black. Sound works perfectly and it still responds to the remote.
Can this be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Varneah Hartungyou can try to see if it is covered under warranty, but LCD damage is usually not. There is no way of fixing it. The panel will have to be replaced. This is where the real trouble starts. Panels that size are not widely available if they are at all. The cost for a replacement panel including shipping will be more than a new TV. You can try and see if you find a set that uses the same panel but has other issues than the panel and harvest the replacement from that. To search for a replacement panel, use the manufacturers label glued to the panel and not your TV model.
这个答案有帮助吗?
得分 1
1条评论:
I bought the TV on auction a few days ago and it was working perfectly. I guess it's during the transport home that it could've damaged. Cost me quite a few bucks so hopefully I can sort it out at a reasonable price. Thanks so much for your advice!!!
完成的
添加一条评论
最有帮助的答案
Best bet would be to return it and get a new one. There are no 70" glass screens that you can buy to replace it. It should have a warranty on it.
Best of luck!
- JR
这个答案有帮助吗?
得分 1
1条评论:
Thanks JR, will try this option tomorrow. Will revert if i'm successful.
完成的
添加一条评论
添加你的答案
Varneah Hartung 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 700
