跳转到主内容
This computer was released by Asus in 2014.
How do I reinstall the system?
I want to reboot my computer, it's slow and the storage is full, even though I don't have much stuff on there. How do I reboot it? I've done it once before, but it was long ago, so I can't remember. The computer is a bit over a year old.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
6条评论:
What OS version do you have installed?
完成的
I have Windows
完成的
Did you empty your recycling box?
完成的
Hi @@feliciaspyan using windows 10 ? If so there is should be option by the OEM inside to reset your pc.
Try This
https://www.laptopmag.com/articles/reset...
完成的
How do I reset it without logging in
完成的
显示更多的1条评论
添加一条评论
3个答案
As indicated by Augustine, use the link to laptopmag.com.
MAKE SURE YOU HAVE ANY FILES YOU WANT TO KEEP/SAVE COPIED TO A SAFE LOCATION (thumb drive, external hard drive, DVD ROM, etc).
  1. Click Start
  2. Type in "Settings" and click "Settings"
  3. Click "Update and Recovery"
  4. Select "Recovery" from the left-side menu
  5. Under "Reset this PC" click "Get Started"
  6. Make sure your files are backed up, select "Remove Everything"
  7. Click the "Just remove my files" option - This should be sufficient for your needs
  8. Click "Next"
  9. Click "Reset"
  10. Click "Continue"
I believe from this point, you should be back to square one and the initial Windows 10 setup wizard will walk you through the rest of the setup.
If you get stuck, don't be afraid to ask more questions.
这个答案有帮助吗?
得分 0
添加一条评论
  1. turn power On
  2. press F9 many times. You will have recovery mode.
这个答案有帮助吗?
得分 0
添加一条评论
Je vs conseil de faire une nouvelle installation c'est plus sécurisé
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Felicia Birgersson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 8,270
