跳转到主内容
加入维修社区 - 创建账户
A1103 型号 / 1.25、1.33、1.42 或 1.5 GHz G4 处理器
How to get out 2 CDs?
My 1½ year old son just popped in a second CD in the drive - how do I get it out?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Your first hope is to boot up your machine while holding the left mouse button.
If this does not work, your best bet is to remove the optical drive, remove the top case of the optical drive (a few screws will remove the case), and pull the CDs out manually.
Keep us posted!
这个答案有帮助吗?
得分 4
4条评论:
I have done this several times with good results. Better than fishing around inside the drive with tools that might damage something.
由完成的
I just remembered actually, I once accidentally jammed a second CD into a stereo, the way I got it out was by taking it apart and removing the drive, so that is a good way to go.
由完成的
The Mac Mini doesn't have any eject button, so that didn't work. The "two-credit-cards-method" didn't work either, it was already too much stuck in there... I found a YouTube instruction video on how to remove the top case and then the two CDs could be pulled out manually. All well that ends well! (And now I've blocked the opening of the CD-drive with a strip of tape outside, so I don't have to do it all over again...)
由完成的
If you have decided against your optical drive, you may be interested in replacing it with another hard drive, a lot of people do that now and it's a common setup
由完成的
添加一条评论
It's honestly better to take the drive apart. Cards may work, but generally not very well. I don't recommend tape at all; this can damage the label on Recordable CD's.
If you do not want to take the computer apart, it may be possible to force eject the discs or damage the drive motor. However, this has a high risk of ruining the drive and it may not work whatsoever.
Here is the guide to remove the drive.
这个答案有帮助吗?
得分 2
添加一条评论
USe the old double sticky tape trick
N.
这个答案有帮助吗?
得分 0
2条评论:
That sounds like a good tip, but if there are already two disks in there, is it a good idea to jam in a third?
由完成的
I highly doubt you'd be able to get a third one in there, to jam it you'd probably have to bang it in with a hammer.
由完成的
添加一条评论
Or try the floppy method.
这个答案有帮助吗?
得分 0
添加一条评论
We had the same issue in our mac mini. I slipped a piece of packing tape into the drive, pressed down with a collar stay (any thin but firm object will work) to adhere the tape to the top disk and, presto, the disc came out super easily!
这个答案有帮助吗?
得分 0
1条评论:
thank you!!! this works for me!
由完成的
添加一条评论
添加你的答案
Sara 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 31
总计 5,460
