跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30、60 或 80 GB 硬盘 / 黑色或白色塑料面板
iPod will not turn ON Ideas?
My ipod will not turn on and is not recognized by my pc or itunes. I have tried charging the battery and resetting the ipod as describe through apple's website. It just does nothing not even light up. Battery life was always exceptional. Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
+ nice description of your actions on the comment
完成的
添加一条评论
3个答案
最有帮助的答案
Mike, the first thing that I would do is to replace the battery. You can of course open it and check the connection of the battery and see if it is on. Also pay close attention to the actual connector, the 5th gen has an issue with the connector coming of the logic board :) step 5 of the guide. iPod第五代(视频版)电池更换 good luck and let us know what happened.
这个答案有帮助吗?
得分 3
2条评论:
Ok. So I replaced the battery and set it to charge but the ipod never lit up or indicated it was charging. I continued to recheck my work all ok. I used a wall outlet charger that is known to be good. I made sure it was off hold and tried to reset it with no response. My pc still does not recognize the ipod being connected.
完成的
At this point with all your connections being in good working order and your battery being new my best guess from here would be that it is your logic board that needs to be replaced. Sorry, wish I would have a better answer for you. http://www.ifixit.com/iPod-Parts/iPod-Vi...
完成的
添加一条评论
Common error amongst these iPods, the magic trick is getting it into service mode. Youtube videos are plenty online: http://www.youtube.com/watch?v=SsWgCLAvt...
Basically connect iPod to Mac / PC, hold menu + enter till restart, then do the same again but before the apple logo (with black background, not the faded grey) quickly switch and hold menu + backward (left), until the service mode appears.
Run all the tests automatically (note: some require interaction), when service test is done, just restart again (menu + enter) while connected to Mac / PC, and wait for it to get recognized by the computer.
(This is especially useful, once the battery is sort of completely empty, doesn't matter how long the iPod has been laying in the dust while turned on.)
这个答案有帮助吗?
得分 1
添加一条评论
You may wish to try plugging it into your computer, opening up the Disk Utility app, and see if it shows up in the left hand pane. Go from there - it may be a software issue. My 80 GB 5th Generation iPod Classic showed a dead screen, and now I'm getting a faint 'Please wait - Very low battery' issue on the screen, so it's probably my battery, although I've basically only used it as a storage device - go figure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 33
总计 15,666
