跳转到主内容
加入维修社区 - 创建账户
iPhone 第五代维修信息和指南。型号:A1387
Unlock disabled iPhone 4s
I have used all the steps required to unlock and restore my iphone4s and during the process a message comes up on my laptop stating there's not enough space for it to carry on ?? Please help how or what do I do next
回答此问题 我也有这个问题
这是一个好问题吗?
得分 25
添加一条评论
4个答案
最有帮助的答案
1) if the phone is still fully operational, connect the iPhone to iTunes
2) connect the iPhone to a computer use iTunes to do a full backup -- If it asks if you want to transfer apps, say "no".
3) put the iPhone into DFU mode (should be a black screen, not a connect to iTunes symbol if done correctly), and allow iTunes to restore the iOS
4) Once it finishes restoring the iOS, iTunes will ask if you want to restore from the backup you just made. Simply agree to that, and you should be good to go.
这个答案有帮助吗?
得分 3
添加一条评论
It sounds as tho you may have to hard restore that device thru itunes before you can get into it at all now
这个答案有帮助吗?
得分 2
添加一条评论
This article will show you steps and tips on how to fix and solve the problem without iTunes.
Disabled iPhone: How To Fix Without iTunes
这个答案有帮助吗?
得分 2
添加一条评论
There are several ways to unlock disabled iPhone 4s according to Apple’s official method. These include: Erase iPhone via iCloud if Find My iPhone is enable. Restore iPhone via iTunes if you have synced with iTunes. Sometimes, these 2 method may not be available for you if you have not synced your iPhone.
If so, FoneGeek iPhone Passcode Unlocker will be available since this tool can remove screen lock when you forgot the passcode.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lindsay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 52
总计 12,391
