跳转到主内容
加入维修社区 - 创建账户
型号 A1419 / EMC 3070 / 2017 年中 / 3.4、3.5 或 3.8 GHz Core i5 或 4.2 GHz Core i7 Kaby Lake 处理器 (ID iMac18,3) / Retina 5K 显示屏。请参考较旧的 iMac Intel 27" Retina 5K 显示屏 (2014 年末及 2015 年) 指南,因为该系统的结构非常相似。
Is the stand removable?
Is the base/stand/foot removable like in older model iMacs? Is a vesa mount possible without direct order from apple?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
Sorry, you'll want to get the VESA mount model.
So far none of the 'Thin Series' offer a user removable foot. The iMac Pro slideware at WWDC implied it will offer a removable foot. But we'll need to wait to see if it ends up being true.
Update (11/21/2021)
The only way to get a VESA mount 27” iMac is to order it explicitly, you can’t really alter things later.
The complete system needs to be taken apart to replace the foot stand and you need quite a few parts.
这个答案有帮助吗?
得分 1
添加一条评论
https://www.youtube.com/watch?v=WFSyl9_9...
这个答案有帮助吗?
得分 -1
2条评论:
Sorry guy this was true with the 2011 iMac and the displays. With the 2012 models and newer Apple altered the design preventing the use of the Apple VESA kit.
Only with the intro of the iMac Pro did Apple re-introduce the older design for the foot assembly. So only that model has a removable foot without taking the system fully apart.
由完成的
Yes, but this is a site dedicated to taking these things apart. There are already guides for servicing all kinds of things Apple hasn’t made convenient. If there were anywhere that could put a guide together to remove this inconvenient foot, this is the place.
由完成的
添加一条评论
添加你的答案
Augustus Cross Mackenzie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 36
总计 10,810
