跳转到主内容
Repair information and guides for corded and cordless power drills.
114 个问题 查看全部
How do I open them and cell replacement
These two old Makita 1434 drill batteries have surpassed the end of their life. I was trying to get a look inside so I could replace the cells but the case has no screws, look at the pictures. There aren't any under the label either.
Their Ni-MH, so can I replace them with Li-on? As long as their the same type of cell (possibly C) it should work?
Thank you.
https://drive.google.com/file/d/15C4ws05...
https://drive.google.com/file/d/1pHSdh8r...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Just a thought, after you get case apart(sonic welded/glued) take lots of pic's to aid in proper reassembly of contacts/wires/etc.
完成的
@oldturkey03 I'm still working on an answer to this...
完成的
添加一条评论
2个答案
已选择的解决方案
Press the button on the side of the battery and pull:
https://www.amazon.com/s/?ie=UTF8&keywor...
UPDATE
LMGTFY
well there are about 8 videos on how to do this on just the first page of my search.
"can I rebuild a cordless drill battery"
Here's one: https://www.youtube.com/watch?v=eCnz9xSt...
这个答案有帮助吗?
得分 4
6条评论:
I know I can get them new, but it's cheaper to replace the cells and get more capacity.
完成的
Updated with Pictures.
完成的
@pccheese thanks for the accepted answer and the nudge over the finish line ;-)
完成的
Congratulations Mayer!!
That's quite an accomplishment and other than @oldturkey03 , it's (500K) pretty much out of reach for a long time to come.
完成的
@mayer congratulations buddy! This is an awesome achievement!
完成的
显示更多的1条评论
添加一条评论
@pccheese sure you can do that. here is a pretty good example on how to. Make a guide for iFixit so I have something to go by when I repair my battery
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
George A. 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 50
总计 3,929
