My DVD will play but the picture is not clear and has blueish tinge.
There is no colour only a blueish tinge to the picture?
@evelfritz make sure that you try a different TV as well and try different inputs on your TV. This could be a bad DVD (try others) as well as a bad cable. Try others as well. If none of that works, you want to consider cleaning the laser. For that you buy a commercially available lend cleaning kit. If cleaning etc. does not help you may consider a bad laser assembly.
This should help to disassemble your 3_2_1 and test it. Let us know what you get. Bose 3_2_1 Disassembly and Test Procedure
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 63
1条评论
Thanks, I had forgotten they sell those. Will pick one up in the next couple of days.
由 Daphne Tarrant 完成的
