跳转到主内容
The Bose 3-2-1 Home Entertainment System is a series of DVD-based home media systems in the Bose 2.1 home theater line. The Bose 3-2-1 Home Entertainment System was sold between 2001 and 2006 and was available in black and graphite colors.
My DVD will play but the picture is not clear and has blueish tinge.
There is no colour only a blueish tinge to the picture?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks, I had forgotten they sell those. Will pick one up in the next couple of days.
完成的
添加一条评论
1个答案
已选择的解决方案
@evelfritz make sure that you try a different TV as well and try different inputs on your TV. This could be a bad DVD (try others) as well as a bad cable. Try others as well. If none of that works, you want to consider cleaning the laser. For that you buy a commercially available lend cleaning kit. If cleaning etc. does not help you may consider a bad laser assembly.
This should help to disassemble your 3_2_1 and test it. Let us know what you get. Bose 3_2_1 Disassembly and Test Procedure
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Daphne Tarrant 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 84
