跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Beloved iPad backlight dead :'(
So my iPad backlight has completelystopped woking. I am typing this in it do my spelling my bad as u can bar,et see the screen. At first only some of the lights would not work, it was slinky getting worse and now it had completely stopped working. I will use it to spplr send see if they elk tic it fir free, it now no where ik at die I still s y and dvh vi fud d she get s bee bevel for,
Update:
Here is what it is supposed to say- i think :)
So my iPad backlight has completely stopped working. I am typing this on it so my spelling is bad as i can barely see the screen. At first only some of the lights would not work, it was slowly getting worse and now it had completely stopped working. I will go to the apple store and see if they will fix it for free, if not i will replace the lcd and if still not what could i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Woah! Lil bro! Backlight circuits can be complicated. I'm certain @refectio with be happy to help you out. I've been biting off microsolderingsupply.com. They have a pretty good selection and should be able to hook you up with the components needed
完成的
Had screen on iPad 6 replaced but now screen shows shadows especially on white background web pages. Repair shop states new LCD because its a backlight issue? I didn’t have problem until they repaired screen and tablet is only over 1 year old. Could The back light issue has occurred when they replaced my screen?
完成的
添加一条评论
2个答案
已选择的解决方案
Okay, I can officially say this problem is sovled, and I needed not a trip to the Apple Store nor a replacement part. The problem was a connector on the LCD. If you look at the LCD back, on the bottom right there is a fpc connector. When I looked at it, it was half disconnected. I plugged it back in, put the LCD back on and sure enough it works now as I am typing on it. If you have a iPad Air LCD with no backlight, check that first.
这个答案有帮助吗?
得分 3
添加一条评论
Doesn't sound like a backlight circuit failure to me. It seems as though your led back light strip has failed, easily fixable by swapping out the lcd in most cases unless you blew the backlight fuse.
这个答案有帮助吗?
得分 1
2条评论:
Now I can type normal, I am on my laptop. First I will bring it to apple and see if they will replace the lcd for free since this started before the warentee expired. If not, then I will just replace it.
完成的
Jonathan, why don't you change the wording on your question now that you can type?
BTW I took a bunch of photos of macs for you, just need the time to get it to you
完成的
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 50
过去 30 天: 160
总计 12,348
