跳转到主内容
加入维修社区 - 创建账户
型号 A1225 / 2009 年初 / 2.66、2.93 或 3.06 GHz Core 2 Duo 处理器
Having Download Decompression Problems
iMac "Core 2 Duo" 2.66 24-Inch (Early 2009) 4 GB RAM
10.6.6
I'm having problems almost every time I attempt a Software update or other software download and update. I've replaced the hard drive, zeroed the drive, reformatted, installed Stuffit 14. TechTool Pro runs clear, 50 pass RAM check, Disk Utility runs clear, Norton Anti-Virus is clear. Yet almost every time I try to download a update I get a decompression error. If I download just one update at a time I can eventually get it to install.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
Poor mayer - when you got a problem it's so weird that nobody knowns an answer, including me. I know your pain.
由完成的
+ for the question--you and John have some of the weirdest problems.
由完成的
I used to getthe same issue along with the actual install going to the install screen but hanging there... + For the question
由完成的
I had that problem before changing hard drives.
由完成的
添加一条评论
3个答案
已选择的解决方案
I can't think of anything... If its not the HDD, then it must be the logic board? Or a component on it, such as RAM, CPU or less likely, the GPU?
Try replacing all the ram with just one good ram stick for starters.. I'm just spitballing some ideas here.
A way to circumvent the problem would be to download the updates directly from their site instead of using software update.
这个答案有帮助吗?
得分 1
3条评论:
Already tried one stick at a time in each slot. There is no problem with the video. Replacing the logic board? You sound like a "Apple Genius" a new board is $1988 and a used one $900. I can tell my customer it may or may not fix the problem. But thanks for the suggestion.
由完成的
So do updates work when you download them directly from apple.com?
由完成的
I had already gotten the updates to install by downloading them one at a time. A couple had to be done multiple times. After installing the new system, I HAD TO RUN DISK UTILITY THREE TIMES AND THEN REPAIR WITH TECH TOOLS PRO TO GET IT TO ACCEPT ONE AT A TIME. sorry 'bout the caps. Will now run them again to see if the updates introduced new errors.
由完成的
添加一条评论
Sounds to
me like check sum errors, would indicate network problems, that may have nothing to do with your end.
N.
这个答案有帮助吗?
得分 0
2条评论:
I ran software update a couple of hours ago, it went through on four different machines. If it is network I doubt if its at Apple's end. Does anyone know how Software Update works? FTP, HTTP, etc.?
由完成的
I updated my 2.8 quad core over the same network to 10.6.6 an hour later with no problems.
由完成的
添加一条评论
zapping PRAM did not work, replacing RAM did not work, re-installing OS did not work...
For the time being, my work-around is to create another admin level account. Within that account, it seems to do fine....
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 2,116
