跳转到主内容
Support and repair information for Beats Solo3 headphones.
56 个问题 查看全部
Fixing no sound in one speaker on blueooth
I am having issues issues with the right side of my Beats solo3 wireless headphones. On bluetooth no audio comes out from the right side and the right side will only work if i jiggle the left side. Both sides work fine when using the aux cable for wired setup. What could be the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
5个答案
最有帮助的答案
Plug in your auxiliary cord to your headphones to device, play some music, and if it works like that than take the auxiliary cord back out, turn on blutooth and both will start working again.
这个答案有帮助吗?
得分 2
8条评论:
I did it and it didn’t work. Twice. Help plz!!!!
完成的
It didn,t work for me either
完成的
Didn't work for me either
完成的
Didn’t work for me either.
完成的
I know this is old, but i just tried this and it worked
完成的
显示更多的3条评论
添加一条评论
I have the same problem too
这个答案有帮助吗?
得分 2
添加一条评论
If anyone is still having this problem I was able to fix my Beats Solo 3 Wireless issue with no sound on one speaker on bluetooth after I followed the instructions on this video: https://www.youtube.com/watch?v=kypDTpO_...
Hope this helps.
这个答案有帮助吗?
得分 0
1条评论:
This doesn’t help at all.
完成的
添加一条评论
It could be a loose or damaged connection, would have to disassemble and inspect to determine the correct issue.
First try a reset etc.
这个答案有帮助吗?
得分 0
添加一条评论
Bruh I don't know what to tell
这个答案有帮助吗?
得分 0
1条评论:
Yeah you might need new ones
完成的
添加一条评论
添加你的答案
MrSnowyOwl 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 89
总计 45,103
