跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
72 个问题 查看全部
Why does my scooter quit running when I apply weight to the seat?
Starts and runs fine, just when I take off the kickstand, and put weight on the seat it just dies
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
I have the same issue.ut runs fine on the stand..starts first time..it will keep running with me walking next to it with the throttle open at walking pace.also run with me on it while in centre stand..but as soon as I drop it of stand with me on it it cuts out instantly
完成的
Even I have the same problem. Mine is a Honda Dio 50cc (Japanese). Starts, accelerates everything fine but when I release the central stand and when the rear tire touches the ground bike shuts down. All the battery connections throughly checked. How to fix it?
完成的
mine will run fine on the stand and when i take if off it slows down and speeds up very slowly and sometimes will cut out and i have tried so much but cant find out i am 15 so i cant legally drive a car yet if any knows whats wrong that would be grate
完成的
I faced the same problem with my hero pleasure.
完成的
添加一条评论
4个答案
最有帮助的答案
@theshadows sounds like either a torque issue or you are cutting something off under the seat. Check first to ensure that the fuel line is not being 'pinched' or that it pulls on some wires.
If it idles okay but does not have any torque you do want to check the compression and see if your engine performs as it should. I'd also would try to adjust the carb. You want to start with the air/fuel mixture screw first. Also check your float height and make sure that the level is right and that the needle valve is not stuck.
这个答案有帮助吗?
得分 2
1条评论:
Kill switch wiring reversed?
完成的
添加一条评论
I found out.that my ht lead was split.everytime i sat on the bike it was shorting out the spark when it touched the top of the
这个答案有帮助吗?
得分 1
1条评论:
Thank you Neil, your answer was useful. I found out a malfunctioning ignition coil and replaced it. Now the bike is perfectly alright. I feel this kind of problems are due to faults in electrical connection.
完成的
添加一条评论
Did you check your battery connections. Sounds like your issue might be an issue. From my understanding, you do need a good battery connection for the bike to run.
这个答案有帮助吗?
得分 0
1条评论:
My 49cc 4stroke scooter shuts off when I shake it back n forth. Where is short?
完成的
添加一条评论
you cvt is messed up. if it dies when you stop and then it's hard to push, your cvt has something wrong with it. clutch is stuck or something in there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
The shadow 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 153
总计 6,832
