跳转到主内容
Repair information and support for GE Profile Refrigerators.
60 个问题 查看全部
Why is my freezer not at 0°?
My refrigerator model is GE Profile side-by -side PS123SGPA BS. Digital temperature panel in refrigerator section has a freezer temperature reading that hovers in 24°-26° range. Noticed it was warm few days ago.
Any idea what I should check or will this require a technician before buying a new fridge?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
@ajultaylor what is the temperature in the fresh food (refrigerator)section?
完成的
It defrosts occasionally. Check it at different times.
完成的
Is there frost on the back of the freezer panel? If so , then the unit is not defrosting and would require replacing one or the following ... defrost thermostat , defrost heater and or control board
完成的
添加一条评论
1个答案
最有帮助的答案
@ajultaylor since we do not know yet what temperature your fresh food section is, follow the flowchart for whatever condition applies to your fridge. At this point I would think that the error is related to the main freezer thermistor, the damper or the control board. Let us know what you find out so we can further assist you.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Drew 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 29
总计 1,766
