跳转到主内容
Comprehensive guides for common repairs on every model of iPod shuffle. Most repairs on these devices are difficult and require prying against adhesive.
162 个问题 查看全部
问题已关闭
Why does my new shuffle not appear in itunes under devices?
I purchased two new shuffles for my sons and neither appears under devices in itunes when I plug them in! I have tried all kinds of things but cannot even set them up! Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
It could be a few things, it could be any combination of software and/or hardware issues but, my first thought is that your computer(s) don't have the minimum required version of iTunes, which is version 10, you can download the latest version of iTunes here for Mac or here for Windows. (you also need to make sure your computer(s) meet the minimum requirements for iTunes 10 as well). My second thought is that your computer(s) dont meet the minimum operating system requirements for your ipod shuffles which are:
Mac system requirements
Mac computer with USB 2.0 port
Mac OS X v10.5.8 or later
iTunes 10 or later
Internet access is required; broadband recommended
Windows system requirements
PC with USB 2.0 port
Windows 7, Windows Vista, or Windows XP Home or Professional or later
iTunes 10 or later
这个答案有帮助吗?
得分 0
添加一条评论
Carrie forget itunes, use this program (ipod copy transfer) so much better.
这个答案有帮助吗?
得分 0
添加一条评论
It is my opinion that you are better off to continue to use iTunes since it has a broader base for people to assist in case you are running into any further trouble. If you just purchased these shuffles they should still be under some kind of warranty. Try to replace them with your seller. The other thing that has happened to me was that the device did not show up under iTunes but showed up in my computer. Do your show up as a USB device when you plug them in? I actually had purchased a Chi pod and it would never sync with iTunes but it did work as a mp3 player under the USB device.. So let us know what you got.....good luck
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,625
