跳转到主内容
加入维修社区 - 创建账户
Yotaphone 2 的型号为 YD201,是俄罗斯 Yota Devices 公司的第二款产品,配有 AMOLED 前屏和电子墨水后屏。
How to replace the battery?
I have Yotophone purchased in UAE and the battery after charging drains out. How can I change the battery? appreciate receiving your reply per return.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
How fast does it drain? When did you get the phone?
由完成的 分享
添加一条评论
4个答案
已选择的解决方案
hello_chandran, You may want to check the 1st and 2nd link below for concerns on battery draining before changing the battery. 3rd link, below is a disassembly video link that will show how to get inside Yota to enable changing of the battery. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://howtodothing.net/yotaphone-2-batt...
http://www.gearbest.com/blog/how-to/easy...
https://www.youtube.com/watch?v=_Kr1dnav...
这个答案有帮助吗?
得分 1
添加一条评论
Its easy.
Just need to remove the cover where the usb port is. Its easy , just glue , Remove the screws and with plastic tool remove the screen from edges. its easy, aa lot of videos in youtube. Dont worry, its not hard.
这个答案有帮助吗?
得分 1
1条评论:
you are right, it's even much easier than shown in the videos
1) you need to remove the plastic cover off the usb port
2) lift off the back screen
3) unplug the 2 sockets of the back screen and remove the back screen
4) unplug the battery socket and remove the battery, which is glued, take care, gently
5) plug the socket of new battery and glue it by gently pushing it into its space
6) reinstall the back scren and the plasti usb cover
It was the first time i did something in a smartphone and it went smoothly all right
由完成的 分享
添加一条评论
Take a look into a Yotaphone's disassembly guide HERE
这个答案有帮助吗?
得分 0
添加一条评论
where can we buy a good quality original battery for YotaPhone 2?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hello_chandran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 41
总计 4,852
