跳转到主内容
加入维修社区 - 创建账户
Sony M-430 微型卡带录音机可以录制和播放音频。它具有一键录音、两种速度的录制/播放以及自动关机功能,非常适合随时随地进行录音。型号为 M430。
The spinners aren't working
I just found an old Microcassette recorder and it worked at first, but after awhile they stopped working and now when I rewind it makes a buzzing noise. Also the little switch on the side has become loose and I can't seem to get it to stay in one spot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
@flamma sounds lik you are having issues with the drive belt. Use these guides to check it out. you will have to unsolder the main board to get to the mechanism deck that includes the motor and the drive belt. Once you have the recorder open, post some images of what you see with your question. Use this guide for that. It will allow us to see what you see.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Jake door 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 2,167
