跳转到主内容
Why the keyboard and the mouse pad dont work well?
When i press the backspace button once , it deletes all what i wrote , and sometimes doesn't work.
And the mousepad works and suddenly it stop working ( i can move the mouse but i can't click), to get it work back i should press the windows button twice.
How can i fix it please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Make sure your drivers are up to date.
Have you run a virus scan?
Have any liquids been spilled on the device?
这个答案有帮助吗?
得分 0
6条评论:
Yup, last year l spilled some olive oil on the keyboard but everything have been ok
完成的
That might be your problem, oil doesn't evaporate like if you spilled water on it, it will have stayed and become more viscous with time and heat, and is the probably cause of the keys sticking; or at least the internal parts of the keys.
I'd suggest replacing the keyboard and the mouse pad.
完成的
what about cleaning them ? can solve the problem ?
完成的
It would be worth a try, if you were up for it, but I've cleaned keyboards before, year old orange juice was causing the same kind of problem as this, initially nothing but then keys started to stick months later.
The problem is that laptop keyboards are mostly sealed units and aren't meant to be taken apart, but like I say worth a shot.
完成的
If you take it out, remove all the keys and clean it under water, and then leave it out to dry for a week and then put the keys back it should be ok.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Dhia eddine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 65
