跳转到主内容
加入维修社区 - 创建账户
一款 Nikon 于 2005 年至 2006 年间销售的数码单反相机。
Battery Clock Icon Blinking
D50 will autofocus, menu will not light up, clock and battery icon blinks, camera will not take a picture.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What I learned and deduced investigating a D50 Nikon repair manual is the clock battery needs to be replaced and it is a real involved job. Have to unscrew the backing, unsolder two wires and remove the holder with the battery. I did not investigate the cost of a new clock battery let alone if it is available.
由完成的 分享
menu works, but where do i reset the clock? the clock icon is blinking and ti will not take a photo. this just atsrted happening
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
charles.james, Ensure that the battery contacts are clean and install a new quality set of fully charged batteries and have charger tested or try another known good working compatible charger to rule it out as an issue. Reset clock and try camera. If problem persist, internal clock battery may be faulty or issue with bad components in camera. Pg D18, of the attached service manual below shows the internal clock battery and disassembly process to enable checking of internal wire connections/components/etc. for loose, damage, burnt. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://ss-it.de/data/servicemanuals/D50....
这个答案有帮助吗?
得分 1
添加一条评论
But how is the clock corrected (to stop it from blinking) after pressing the bottom reset button? This clock blinking happens immediately after pressing the reset button, and the other case of a faulty internal clock battery is another different issue. I don’t know which buttons to press to activate the menu and other buttons. What are the steps to make other buttons work?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
charles.james 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 12,979
