跳转到主内容
加入维修社区 - 创建账户
这是一款专为教育用途设计的坚固耐用型 Chromebook,配有加固接口和铰链、防剥落按键、密封触摸板,并拥有 9.5 小时的电池续航时间。
Why won't my touchpad respond?
I can turn on the laptop and use the keyboard but every time I try to move the cursor around it still doesn't move. Once in a while if i keep trying I may get a very slight movement.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Student Question
完成的
添加一条评论
2个答案
I had this problem too. Your touchpad is most likely partially disconnected inside the device. I fixed it easily by opening up the Chromebook and reconnecting the touchpad to the motherboard. This can happen when your Chromebook experiences a drop or a hard hit.
这个答案有帮助吗?
得分 1
8条评论:
So you guys joined the site the same day and join the same 4 man group, post about the same device and comment on each others posts?
You guys just really into the N21 or is there another angle here?
完成的
Hi @thethirdtwin ,
They may be students doing projects under the auspices of ifixit, learning how to answer technical questions.
That is usually the case when you see schools mentioned in their profile
When I notice that I leave the answering to them unless it is totally wrong ;-)
You may also notice that the moderators leave a comment of 'student question' if they spot it first
完成的
I figured as much, but they're answering each other questions which I thought was weird. But if you've seen this before I'll leave them to it.
完成的
Fair enough.
I only take more notice if they don't have a 'school' mentioned in their profile (which can happen) and if their answers make no sense at all, are totally misleading even malicious, are rude etc etc.
完成的
@thethirdtwin yes those are indeed students. You can easily identify them by clicking on their "avatar" where you notice that their team is "Cal Poly, Team S21-G2, Livingston Spring 2017" Anytime you notice weird things like this, double check. If they are not students, then you know we'll deal with it. Thanks for being vigilant
完成的
显示更多的3条评论
添加一条评论
最有帮助的答案
Can you click it down? If not the screws may be too tight. Also try powerwashing it as it could be softwere. As a last resort and the most likely cause open it up. The ribbon cable probably wiggled loose.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrew Luong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 2,972
