跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 个问题 查看全部
问题已关闭
Is not charging showing usb plug symbol only.
Just install a new battery 616-0435 from ifixit and for some reason the phone won't charge at all. When plugging in the charger it will show the lighting symbol real quick then turn into usb plug symbol.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What happened that made you change the battery? Did it charge okay before you replaced it?
完成的
添加一条评论
6个答案
已选择的解决方案
check connector 4 is on and clean
check battery screws under don't remove sticker are on properly
try different charge lead
try reset- press and hold power and home button for 10 sec then allow to reboot
这个答案有帮助吗?
得分 2
2条评论:
didn't work,do you think is something have to do with the latest iphone firmware from apple causing the problem?
完成的
most times when you can't charge the problem is hardware. the points easiest to fix are battery/power connections. after this you're looking at motherboard parts which are tiny.
Have you also checked the dock connector pins etc? any chance you may have damaged them?
If this doesn't work then I'd put the old battery back in and see what happens. If it works then you should send the new battery back. Check that the part number on your old battery matches that on the new for next time.
Go ahead and try to restore phone but if it isn't charging you may not be able to complete the restore and will get error 21 etc from itunes
完成的
添加一条评论
My parents short curcit the original battery by plugging the charger to outlet. When it happen the iphone only showed a broken battery sign everytime I turn it on. From there replace it with Ifix battery and it worked except charging sign,restore the phone 10x times include updating it to 4.2. But something is wrong because now it charged for 10-15 sec then usb symbol comes on. Before that it would do lighting symbol then switch to usb symbol real fast.
Think I got a bad ifix battery?
这个答案有帮助吗?
得分 0
4条评论:
should I drain the battery??
完成的
I think pollytintop is right on this one. I wonder if the overcharge shortened the charging circuit and therefore your battery really does not charge. I do not think that you got a bad battery. It's not impossible but I doubt it.
完成的
how much does the logic board go for?
完成的
There are a couple on here, not cheap.http://www.buycheapr.com/us/result.jsp?g...
完成的
添加一条评论
Apparently there are two fuses that are on your logic board I believe that may actually be part of the problem. I figured that there is a possibility that the accidentally overcharge may have "blown" on or both of these. Here is a link with the location of these. It might help to check on them before replacing the logic board....http://forum.gsmhosting.com/vbb/f631/iph...
Hope this will help you out.
这个答案有帮助吗?
得分 0
添加一条评论
Well I have the issue where when I put in a "new" battery it will flash the bolt then go to the usb symbol and not charge. I am thinking that it is an issue with the batteries because when I put back the original battery (complaints of not holding charge as long as they thought it should) it would charge perfectly fine. I tried literally three other batteries and all had the same issue. Battery issues are extremely annoying to try and fix, because with a screen its pretty apparent whether it works or not, but with the battery you never can really tell. I've installed some only to have people come back and complain about charging issues etc. I would love to hear from someone else who has experience with this and/or knows where to get consistently functional batteries.
这个答案有帮助吗?
得分 0
添加一条评论
Any update on this? I have a similar problem. My friend has an iphone 3gs where the ringer stopped working. I researched this and it seems the speaker went bad in the dock connector. I ordered a new dock connector and installed it. The ringer now works, but the phone will no longer charge. It shows the symbol that it's plugged in, but doesn't show the lightning bolt anymore. I swapped back the OLD dock connector which never had a problem charging, and now it doesn't charge either!
I'm willing to try more troubleshooting. Please chime in if you can.
这个答案有帮助吗?
得分 0
添加一条评论
Solution!
I faced this problem too.i tried many ways but i could not solved this problem.so i bought a new apple genuine charger whos voltage is very accurate(4.7 watt and 1mA).now my iphone charged very quickly and am so happy.thanks a lot for my solution.
i hope your iphone will charge easily and correctly without any problem
For more in formation contact me at
+923144666081
djchamp360@hotmail.com
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 23,381
