跳转到主内容
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Left and center channel swapped
Hello, I am having a problem with my HyperX Cloud 2. I had to buy a new jack, and now I am having an issue with the sound channels. The right one is fine but the left channel is played like the center and center is played only from the left speaker. Microphone and right channel work perfectly. Any ideas?
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You must have wired it wrong. This is what it should look like (make sure the colors are correct):
Hope this helps.
这个答案有帮助吗?
得分 3
2条评论:
I have jack with wires already I am just connecting the wires together.. But thanks for help I had the wiring wrong and it works now :)
完成的
Glad I could be of assistance.
完成的
添加一条评论
添加你的答案
Jakub Setnicky 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 980
