跳转到主内容
加入维修社区 - 创建账户
这款笔记本电脑于2010年9月发布,型号为 Inspiron N5030 或 Inspiron 15。这是一款全黑色的笔记本电脑,顶盖中心印有 DELL 标志,配有一个左右键分离的触摸板,电脑右侧配有光驱。
compatability of ram and cpu
I have a dell inspiron 15 N5030 with a Pentium T4500 dual core cpu and just bought 2x 4GB DDR3 1333 (CP3-10600) SODIMM chips for upgrading....I want to upgrade the cpu to the Pentium T9500 core duo cpu and want to know if it will support the same ram chips I bought? thank you very much for your time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Stephen -
According to Dell support site (http://downloads.dell.com/Manuals/all-pr...) Page 75, the N5030 will support up to 4GB of DDR3-1333, so you should be Ok.
Russ
这个答案有帮助吗?
得分 2
3条评论:
He has 8 Gb of ram that he got. So he wont be ok.
由完成的 分享
Ooops! Thanks.
由完成的 分享
A lot of time, they only test out to 4GB but, I have put in twice that amount and had it work with no problem. It will probably be fine.
由完成的 分享
添加一条评论
Russ above said that it supports 4gb but i find that its very possible that it can support 8gb.
Give it a shot. As long as you have a 64 bit version of windows, you should see all 8gb. It wont hurt anything if you do not.
Hope this helps! If it did please hit the accept answer button!
这个答案有帮助吗?
得分 1
添加一条评论
thank you everybody for your input....yes I have a current 64 bit windows system....I am currently waiting for that 8GB worth of DDR3 1333 CP3-10600 chips cause I found out the stock t4500 is a 1333 system...am I right in assuming the stronger 9500 would support the same amount? and is it a 1333 cpu also? or more...I can't find the specs anywhere
这个答案有帮助吗?
得分 0
3条评论:
Instead of upgrading the CPU, you would get a better speed kick if you upgraded the hard drive to an SSD.
由完成的 分享
I know ssd drive is way faster than my current hard drive in my dell inspiron 15 N5030 that is running at speed of 5400rpm...I want to know if installing an hdd drive at 7200 will increase my speed more than upgrading the stock t4500 cpu to t9500 at an increase of 2.3ghz to 2.6?
one other factor you should know is that I have the ram maxed at 8gb dual channel and is running at a speed of 6-6-6-15 clocks/latency which I've been told is faster than the chips were designed for
由完成的 分享
Hello Stephen,
Have you got success with upgrading CPU and RAM memory?
由完成的 分享
添加一条评论
添加你的答案
Stephen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 21
总计 2,430
