left side speaker not working properly.
It works perfectly fine if the jack is connected. but the left side of the headphone doesn't work while using on wireless.
Hi @hanamichhi ,
Does the BT audio cut out when you insert the aux. cable? (the other end of the cable doesn't have to be connected to anything). If so I'm wondering if you might have a faulty aux. input socket or the wiring connected to it
The wiring circuit in a lot of BT speakers, headphones etc. is that the audio from the BT goes through contacts in the aux. input socket to the amp/speakers, which changeover the audio source from the BT to the aux socket when the plug is inserted.
To find out you'll have to open the headphones where the aux socket is and inspect it. The left earphone is connected to the 'tip' connector (and its' associated contacts of the aux socket) Just a thought.
这个答案有帮助吗?
@hanamichhi akashshrestha30 , Try this, Go to System Preferences > Sound > Output > Balance ( Set the balance at the middle ), info from link below. If still no improvement perhaps try resetting(link #2) resetting and trouble shooting. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 39,801
3条评论
So, what i did was, plug the audio cable in WHILE bluetooth was still on, and then took out the cable, turned off bluetooth, turned it on then reconnected 8t
由 ai zawa 完成的
Had the same issue.
This solution worked for me!!
Thank you!!
由 Diana 完成的
It works, but why does this work and is this permanant?
由 cheongedward 完成的
