跳转到主内容
加入维修社区 - 创建账户
海尔制造的笔记本电脑的维修信息和拆解指南。
Some keys of keyboard NOT Working?
Some keys of keyboard NOT Working ??Like N,space,ALT,B,C.ENTER key .How can i repair..If it cannot be repaired and need to changed keyboard of my haier laptop ?Which keyboard model can fit into this laptop.Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 14
15条评论
faraz0920 what model is your Haier Laptop
完成的
Haier YB11 PM Nawaz Shareef
完成的
Hello,
We have an laptop y 11c ,its keyboard has been stop functioning because of few drops of water have spilled on it, i want to change its keyboard so that it could function like earliar..
完成的
i have new hair laptop of prime minister and some keys of keyboard not working now what i do bro
完成的
If it's new, take it back to where you bought it.
完成的
显示更多的10条评论
添加一条评论
4个答案
已选择的解决方案
I don't know this make of laptop, but for most, swapping the keyboard is fairly straightforward. You may have to remove a bezel between the keyboard and the hinge to gain access to the required screws, or you may have to remove one or more screws from the back, or indeed the keyboard may just clip in place. Then you just need to be a bit careful in releasing the ribbon or ribbons connecting the keyboard to the motherboard. You probably wouldn't be able to fix the troublesome keys in your existing keyboard.
You will need a replacement keyboard for the exact same model, and make sure it's the right language, but hopefully you can find one on eBay.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Guys, for Haier y11c, the best option is to disable the keyboard and use an external one. The best method I’d recommend is to disable the keyboard hardware by opening up the laptop and detaching the ribbon cable. This way you will not have to put up with any funky software. You could try disabling it through a software called KeyTweak.
Other than that, replacing it might cost you around 4-5k PKR since the keyboard is chiclet-style and you will have to replace the whole panel. This is just not worth it.
这个答案有帮助吗?
得分 3
1条评论:
In my case, the key tweak is working very well. At least there's no need for an external keyboard now, although my first two rows are dead. I have replaced some necessary keys and also touch keyboard as well helping me out.
完成的
添加一条评论
The keyboard is faulty and needs to be replaced to solve it.
这个答案有帮助吗?
得分 1
添加一条评论
Visit following link .
https://youtu.be/AZS4osYJ_C8
这个答案有帮助吗?
得分 1
1条评论:
Irrevent solution.
完成的
添加一条评论
添加你的答案
faraz0920 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 64
总计 17,312
