跳转到主内容
加入维修社区 - 创建账户
Chevrolet Malibu 是一款由雪佛兰(Chevrolet)从 1964 年到 1983 年生产,并于 1997 年起恢复生产的中型轿车。Malibu 最初是雪佛兰 Chevelle 的一个配置级别,于 1978 年成为独立的车型系列。最初,它是一款后轮驱动的中型轿车;1997 年,通用汽车(GM)重启了 Malibu 车系,并将其改为前轮驱动。
How To Replace MAP Sensor?
I'm a pretty handy person. I've been getting the "SVC ESC" error message and the check engine light on my 2012 Chevy Malibu LT 2.4L, along with rough engine idle. After doing my homework I need to replace the MAP sensor. I figure easy enough, problem is I have a vague idea where it's located. I've scoured the net trying to find something solid whether a youtube video or forum with some sort of way to pin point or show me the location and a possible how to access the place if not easily obtainable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
pierce2784 @lpfaff1 has answered the MAP however to address the "SVC ESC" error is a different story . This stands for service electronic stability control. this could be caused by a host of things. If you have access to a OBDII with ABS functionality you will find it a great asset in diagnosing the problem . If you have an ABS light on at the same time it could be anything from dirty tone rings to metal filings sticking to the sensor head. It can also be the ABS pump not functioning properly or something as simple as the yaw sensor. Some cars have this located under the passenger seat and occasionally if something gets jammed in under the seat it can affect how it works. It can also be caused by bad struts, a loose swaybar ,bad wheel bearings , seized brakes .or a faulty steering rake. Its hard to narrow it down without a proper inspection . Hope this helps
这个答案有帮助吗?
得分 2
4条评论:
Thanks @jimfixer , I was reading up on the SVC ESC error and you beat me to it, good assist, thanks again.
由完成的 分享
@lpfaff1 always happy to help out . I kinda wondered if you were finished there or not .
由完成的 分享
@jimfixer , Some times I get reading and one thing leads to another(time flies). thanks again.
由完成的 分享
@lpfaff1 Watch what your answering tonight theres student out on the forum . I just trolled one by accident Why can't I connect to my printer?
由完成的 分享
添加一条评论
pierce2784 , replace the MAP sensor. link below may help, 2nd link is the replacement sensor to aid in what to look for. See below for SVC ESC error info. by Jim. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=OMmrjtDg...
http://www.jcwhitney.com/1997-2012-chevr...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
pierce2784 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 35
总计 8,103
