Unit doesn't spin FO2 keeps coming up
What causes the fo2 and doe it lock out the spin cycle
Scott Hayman , You did not state your exact model#, if Kenmore Washer Oasis Model 110 Top-Load Washer, Possible loose/corroded connection on control board, also follow wires from control board down and check all the connections to components. Found this information at the link below. Kenmore Washer Oasis Model 110 Top-Load Washer F02 error code, User interface failure. Unplug the washer. Open the console and check the wire harness connection between the main electronic control board and the user interface control board. If the wire harness connection is okay, then the user interface control board will need to be replaced. 2nd link is a guide to enable access to control board. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.searspartsdirect.com/washer-r...
Kenmore 110 Series Washing Machine Electronic Control Replacement
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 104
1条评论
@haymanrefer what exact model is your washer?
由 oldturkey03 完成的
