跳转到主内容
加入维修社区 - 创建账户
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
Is there a 'unibody' Mac mini teardown manual?
We're looking into getting a new unibody Mac mini soon. We wanted to know if the new thicker hard drives would fit. Does anyone know if there is a unibody teardown manual that might have this information?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
From a visual standpoint it looks like these use 9.5mm drives from the factory. These may take 12.7mm drives, but I'd check with a deck of cards to be sure unless you have a spare 12.5mm drive you can quicky use. If you'd rather be safe stick to 7-9.5mm drives. However, you need a drive with a SATA II compatibility mode and cannot use a Fixed III drive.
Follow this guide to change the hard drive.
这个答案有帮助吗?
得分 3
3条评论:
Thank You nicksmacandpchelp!
The current Mac mini is MC270*. Is there much difference between it and the A1347?
完成的
+ The MC270 is the A1347.
完成的
OK, THANKS for clearing that up.
完成的
添加一条评论
添加你的答案
AngelArs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 1,489
