跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
208 个问题 查看全部
Washing Machine will not go through a full cyle
Picked up this washing machine. It does not make it through a full cycle. SD comes up on the digital and I have tried to use affresh on the clean cycle but it won't even make it through that. Any guidance would be great!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@dirty838 the SD error can also be tripped by issues with your drain pump. Since you just moved the washer etc. it is conceivable that this caused some disruption with the regular flow of water and drain.Drain pumps cannot drain suds out of the washer. Check the drain hose and make sure the hose is not plugged or kinked. Press pause/cancel twice to clear the display. I would definitely take a look at that and run the diagnostics mode for the washer as well Maytag Bravos Diagnostic & Troubleshooting
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
@dirty838 ,Travis, These machines require you to use proper detergent to not create excessive sudsing HE detergents in correct amounts, recommended in the manual. Follow detergent manufacturer's or manuals directions on the use of product. Try running a wash cycle with just water. See links below, they will tell you how to put washer in diagnostic mode, to retrieve codes to see what faults are possibly a drain pump/clog issue and trouble shooting links, manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://applianceassistant.com/Washer-Re...
http://producthelp.maytag.com/Laundry/Wa...
http://laundry.manualsonline.com/manuals...
这个答案有帮助吗?
得分 2
2条评论:
Thank you so much for all those links. I finally found the solution.
完成的
So what was the issue? I’m having the same problems
完成的
添加一条评论
添加你的答案
Travis Sanchez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 49
总计 14,224
