跳转到主内容
加入维修社区 - 创建账户
Dell Vostro 1400 是针对小型企业推出的系列笔记本电脑之一。该设备配备 14 英寸屏幕,于 2007 年 7 月发布。
Battery life is short
I have had my Dell Vostro 1400 for almost a year now and the past few weeks the battery has not been lasting long. I will charge it all the way but still the life will only last for about 4 hours. I went and bought a new charging cable so I that is not the problem. How do I know when it is time to replace the battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
The best course of action would probably be to take it to an electronics shop and have them look at it, but given that it has such a short charge life it is most likely time to get a new one. You can find a replacement guide for the battery here.
这个答案有帮助吗?
得分 1
1条评论:
Its pretty obvious the battery is going as its probably almost 10 years old. and 4 hours is still a decent charge as it probably didnt get much more when it was new. If it was 1 hour or less, get a new one but this one should last for another year or 2 yet.
由完成的
添加一条评论
@kennedyhallmark,Kennedy, This is directly from Dell official site. All rechargeable batteries wear out with time and usage. As time and cumulative use increase, the performance will degrade. For the typical user, noticeable reduction in run time generally will be observed after 18 to 24 months. For a power user, reduction in run time generally may be experienced prior to 18 months. We recommend buying a new Dell laptop battery when the run time does not meet your needs. See links below for more info. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.dell.com/content/topics/globa...
https://www.howtogeek.com/172362/how-to-...
这个答案有帮助吗?
得分 1
添加一条评论
How do you know when its time? Its time when it dies within an hour or so. The fact that it lasts 4 hours is still pretty good for a 10 year old laptop. When the battery lasts less than an hour thats when its time to replace. You should have replaced the battery as the charging cable was fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kennedy Hallmark 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 497
