跳转到主内容
加入维修社区 - 创建账户
LG 于 2014 年秋季发布的一款大屏智能手机。LG G3 (D855) 拥有 Quad HD IPS 显示屏和 1300 万像素摄像头。
LG G3 Blue Screen
The Lg G3 will flash the logo sign and then after a second the screen flashes blue. Is it a software or hardware issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 14
1条评论
For 9 min at 350 Fahrenheit? Will it not melt? Do I remove the heat Shield?
由完成的 分享
添加一条评论
9个答案
最有帮助的答案
Not sure...but I had the same problem and fixed it. I opened up my LG G3 (unscrewed it open), took out the motherboard. Preheated my oven to 350° fahrenheit and stuck it on a cookie sheet (on foil) for 9 minutes. Put it back together and now my phone works even better than before...it's a lot faster. I found this trick on YouTube. Look it up...it works. I'm super happy that I didn't lose any of my internal photos.
这个答案有帮助吗?
得分 7
6条评论:
This procedure worked for me. Baking the mobo allowed it to start up again, like magic.
由完成的 分享
Did you unscrew anything else or just the mothevoard with the other parts on it?
由完成的 分享
problems finished in phone ? didnt blue screen problem happen again ?
由完成的 分享
Thank you so much for this post! I went to youtube and found a great detailed video. MUCH APPRECIATED, you saved me $$$ (at least for now)
由完成的 分享
Yes also had to do this and works like a charm... but only put in for 7 minutes was afraid of baking it wife is quite happy now.
由完成的 分享
显示更多的1条评论
添加一条评论
It is a hardware problem. The processor is unpacked. You have to heat up the motherboard , but is a temporary solution. After a time the phone will do the same problem.
这个答案有帮助吗?
得分 5
2条评论:
This was a fantastic solution but all of the pictures and contacts, saved messages, etc from this year are gone. Any advice? Pretty upset.
由完成的 分享
yes it is fantactic solution but it happens again and again. I have same problem in my phone , I try what I found in internet to solve my problem
由完成的 分享
添加一条评论
Sounds to be software although you cannot rule out hardware issue completely. First, you should try to factory reset the device. While off, god the power button and volume down button. When the LG logo appears, release and then re-hold the power button while always still holding the volume down button. The factory set menu will appear and you can attempt to reset the device. This should fix all you problems.
这个答案有帮助吗?
得分 4
5条评论:
First How turn on
由完成的 分享
it is not an absolute solution. problem happens again in phone . it is temporary solution.
由完成的 分享
iPhone guy doesn't know s%$t. It's not REMOTELY a software issue! "This should fix all you problems", UMM NO!
It's a heatsink issue with the processor.
I really hope you don't try charging people money for your ill thought advice.
由完成的 分享
I cant see how anyone could say thats software and do a factory reset. Thats what support you get from applecare for an extra 100$ during purchase :)
由完成的 分享
I had bootable LG G3 with other problems, did heat gun work on some chips and now I have this blue screen after booting. Definitely HW issue not SW.
由完成的 分享
添加一条评论
Oven at 180º for 10 minutes works like a charm :D
这个答案有帮助吗?
得分 1
2条评论:
180 Celsius same as 350 Fahrenheit
由完成的 分享
I was initially thinking that this must be joking but on the other hand, I had nothing to loose. Tried this one, cooled down, inserted battery and SIM card, switchd on eht power back and it started to book normally. Unbelieveable! Now phone is working again as like before. (4.5 yrs old LG3). Thanks guys!
由完成的 分享
添加一条评论
You don’t need to bake it. Just take the back cover off, remove the battery, turn it face down, and let it cool for ten minutes. Every time this has happened to me, I’ve done the same thing and it’s worked every time.
这个答案有帮助吗?
得分 1
添加一条评论
I just stuck a piece of plastic in the phone and sometimes it works
这个答案有帮助吗?
得分 1
添加一条评论
Is it the heat or the dehumidifying that helps?
这个答案有帮助吗?
得分 0
3条评论:
The heat helps to fix the soldering connected to the processor. De-humidification won't solve it in this instance. Kinda like "fixing" the original Xbox 360 red ring of death -- however, because this is obviously a smaller unit, it helps.
The issue with the 360 was that after certain heat and cooling, the graphics card warped and made a connection with something else that it shouldn't have.
Be careful with the motherboard, though. I think 8 minutes is more than enough; you don't want to burn the thing. But it needs to get hot enough to make a difference.
Once it was cooled enough for touch (or common sense), put it back in, replace all other parts and screws, should work. At least, it did for me, and I was $@$*!&%& bricks at first.
In the meantime, start saving for a new motherboard, just in case. You can never be too careful.
由完成的 分享
BTW, I did add a little folded up square of alfoil between the processor and the backing, as a makeshift heatsink. Seems to be ok for the moment.
由完成的 分享
Hmm, i took the motherboard out and put everything in a sealed bag with silica gel packets for about 16 hours. Everything worked great for 3 days and then it blue screened again. I just put a .005” brass shim between the processor and backing, if that doesn't work i may try the oven.
由完成的 分享
添加一条评论
Had the same thing happen to me (actually bought dead phone on purpose but whatever) so I did this, as I didn't want to use owen (my parents probably wouldn't let me anyway): I took my hairdryer (2500 W), put extension that makes air more focused and precise, took the board out and blazed the SoC for few minutes. Note that I held SoC down all the time. So it worked and i placed paper between screen and SoC, thick enough to keep SoC pressed and possibly enchance colling a bit (as G3 doesn't have any cooling and thats such and failure but whatever). I hope it doesn't die again but I am confident it won't.
这个答案有帮助吗?
得分 0
添加一条评论
best fix is to throw lg devices away and buy a quality product if not clearly its a hardware / heat sync / pressure / thermal compound/ cooling related issue like most electronics made 2018 and above. Designed to work just long enough to get past that warranty state. To tackle issues like these us real techs / iPhone techs (excluding iphonetechguy ) we. Can use heat guns , heat wave ovens with successful results . Sad part is its never a perm fix without properly reseating the pins aka reballing which is to big a job for suuch cheap devices. See how they got every angle covered the big corps. Sad hustler world we live in.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tori Hawk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 49,411
