跳转到主内容
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530 个问题 查看全部
iBook beeps and flashes when turned on
My iBook has just become the latest computer to die on me, and now i'm reduced to writing this from a phone's browser.
(iFixit works well on a phone)
I was typing in pages '06 when the screen froze and the keyboard and trackpad stopped working. i held the power button to turn it off and now when i try to turn it on i always get 3 beeps and after that the sleep light flashes 4 times every few seconds. it doesn't give me the chance to try fsck -fy or hold c with a hardware test disc. do i need to reimage?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
Referring to Apple's Knowledge Base (http://support.apple.com/kb/HT1547), 3 audio beeps followed by a repeating pattern of 4 flashes indicates "no good banks" of RAM detected.
If you have added RAM in the expansion slot under the airport card, try removing it and booting without it installed. See this ifixit article: iBook G4 12" 1.33 GHz RAM Replacement for location.
If you get the same error without additional RAM, then the RAM soldered to the logic board has failed, and a logic board repair/replacement will be required.
这个答案有帮助吗?
得分 8
1条评论:
Thanks to David for a really good answer! Problem solved for us!
完成的
添加一条评论
this means that there are no good banks (ie ram/memory)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
QEII Student IT 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 4,402
