跳转到主内容
加入维修社区 - 创建账户
丰田 Camry 在日本以外所有市场的第三代车型。1991-1996 年的车型也称为 XV10 系列 Camry。
Cam sensor location no spark issue
I have been trying to get this car going for about a year.told that the cam sensor is gone and need to replace it.now I'm no expert but I do know that I have watched a few videos on YouTube and where they show the cam sensor to be at it isn't..Then told that it's apart of the distributer shaft.!!!!! So if that's the cam where's the Crank shaft sensor? I ts a no spark issue
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@lowvisions , Patrick , On the 2.2l engine, crank position sensor is behind the crank shaft pulley/balancer. Picture below(crank sensor circled). For the V6 3.0l almost same position, see video link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=M6zU6jh8...
这个答案有帮助吗?
得分 3
4条评论:
I'm sorry I should of mentioned that I have a 3.0
由完成的
Patrick, For the V6 3.0l almost same position, see video link. Thanks for replying back.
由完成的
On the 2.2 do u have to take the timing cover off to get to the sensor
由完成的
We have a 1996 Camry LE 2.2L 4 Cylinder... I have bought the crankshaft position sensor, I just dont know where the heck to install it, where is the old one? Anyone know? I searched it up on youtube but i could not find anything. I hope someone can help
由完成的
添加一条评论
Hi for all Ihave toyota corolla 1993there’s no cranck shaft sensor but there's acumshaft sensor biultin within the main distributor shaft making signale to the ECU of the car
这个答案有帮助吗?
得分 0
2条评论:
Well I have remove my 2.0 l and installed a 2.2 l engine , and the car didn't use a distributor , it uses coil which depend on a crankshaft sensor
由完成的
@elicaannephembani And the point of bumping a thread that's almost 2yrs old is...? Are you having issues? Or what?
由完成的
添加一条评论
添加你的答案
Patrick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 75
总计 10,702
