跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Where to by pass with the jumper
My lid lock assembly only plugs into one spot and that's the control board do I go to the lid lock assembly under the hood and cut the wires and bypass it or do I pull the plug from the control board and jumped it there if I have to do it under the machine at the assembly I'm going to have to wire nut the wires together it's model# 1105072011 Kenmore residential washer or wire harness red white blue and yellow wires please help I have 5 kids and haven't done laundry in 3 days I tried to fix this all weekendthank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
so I join red and blue together and white and yellow?
完成的
@mrt22431 applying a jumper is not quite the same a joining them together. Get a piece of cable with some alligator clips or either end and connect as suggested in the answer
完成的
Where does the grey wire from the lid switch harness plug in under the washer on a kenmore 80 series. The wire came unplugged when the motor was removed to replace a part
完成的
添加一条评论
3个答案
已选择的解决方案
@grim69
bypassing the the lid switch should be Blue and White (2and3 on J15) the lid switch . To bypass the lock switch should be #3 on J15 to #5 on J16. Careful of the voltages.
这个答案有帮助吗?
得分 3
16条评论:
Then should I jump both locations to eliminate the entire assembly
完成的
So white to blue on J15 and white to white on J16 please let me know if this is correct thank you
完成的
That sound sabout right and looks correct on the schematic. Just mind the voltage. you got 120V on that
完成的
I just cleared the drain pump had a sock stuck in it started the machine would not lock so put the dial in drain and it drained so should I only have to jump the lock switch or lid switch or the lock switch or still both getting closer thank you
完成的
most likely just the lid switch since the solenoid for the lock switch is activated differently.
完成的
显示更多的11条评论
添加一条评论
最有帮助的答案
Here's what to do till the part comes in:
https://www.youtube.com/watch?v=j8rrZIxA...
这个答案有帮助吗?
得分 5
2条评论:
What gauge ( size) wire should I use, or does it matter?
完成的
I'd use a 16 or 18 gauge wire.
完成的
添加一条评论
As the original answer stated with schematic. Blue to white on j15 will get you the lid sensor. White to white on j15 to j16. If you want lid sensor and lock sensor. Combine all 3. . J15 is cut blue +white. And I nicked the j16 white and spliced online.
Doing a load now. Worse case you just need to unplug machine to reset it, but at that point who cares.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eddie lynn 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 30
过去 30 天: 156
总计 39,524
