跳转到主内容
加入维修社区 - 创建账户
Sony Xperia M4 Aqua 于 2015 年 6 月发布。它配备 5.0 英寸屏幕,运行 Android 5.0.1 操作系统。Sony Xperia M4 Aqua 提供 8 GB(2 GB 运行内存)或 16 GB(E2306 型号)存储空间。它拥有 1300 万像素的主摄像头和 500 万像素的前置摄像头。该手机内置一块 2400 mAh 不可拆卸锂离子电池。
Phone stopped powering on... maybe a possible fix!
Okay... so i had a m4 aqua with no screen output, but it responds(let's refer as first phone). Recently i got a cheap m4 aqua that only needed to swap the battery so i did it and it worked for some time( let's refer as phone 2). I don't know why the phone 2 is not turning on anymore(something with power delivery i'm guessing). Now that i opened both phones to check differences i saw that there are some parts missing from the first phone that are on second(pics attached) maybe it's possible to somehow combine 2 into 1 and make 1 functional phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
on phone 1 there is one missing LCD Filter part, you dont need to take component on phone two and resolder it on phone one. just do the jumper to makes LCD on phone 1 works again..
i hope this helps
这个答案有帮助吗?
得分 0
2条评论:
So you are saying it's possible? How to do the jumper thingy?
完成的
i have done many cases like that.. just see on my instagram page @masterdogen_qualityrepair
完成的
添加一条评论
I have also same problem.. After pressing the power key.. Sony logo come then release the power key.. Mobile get shut down
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
igors riekstins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,619
